http://www.hypex.nl/docs/papers/ncore wp.pdf
very cool, but WHEN will something of the new range go on sale???
hypex need to be careful here, not to invoke too much of the osborne effect.
Osborne effect - Wikipedia, the free encyclopedia
very interesting! Looks like Mr Bruno's been hard at work after all... 🙂
While what you say about the Osborne effect can be true, it sounds as though they are ready to launch soon.
I'll be curious how the "updated" UCD's compare to the N-core, and to the current lineup.
Looking forward to seeing what the products look and sound like (and what the prices look like 😱 )
Guys, please check this link as well; Ncore Announcement
"Hypex owes much to the DIY community for support and feedback, so to those eager to discover Ncore for themselves: keep your eyes open in the fourth quarter of 2011!"
fourth quarter! 🙁
OK, I'll start saving my money. I've got too many projects backing up right now anyway 😉
I think your did a good job, the measures are excellent, sincere compliments. I have a question (I think that is of common interest to others, to understand better measures). how many volt supply your smps1200 (at idle) on the sample under test?
Roberto P.
Roberto P.
I do not exactly understand your questions, but if you would like to know all details of the used SMPS please check this link; http://www.hypex.nl/docs/SMPS1200_datasheet.pdf
Regards,
Jan-Peter
Regards,
Jan-Peter
thanks for the reply, but the question is: smps1200 outputs at those volts? on new sample under test? eg. + / -70V or 80V etc? (at idle).
Your measures not show this info.
Regards,
Roberto P.
About +/-89V idle, dropping to about +/-72V under full load. The leaflet presents the amp/smps as a combo which is why this info isn't there. A full data sheet for the amp alone is under way.
Thanks Bruno, I asked for understanding the behavior vs. power, it is clear that the measure would not show at the real clipped , if so, to 4R should be about 600W (not 420W). I assumed your power stage to lose only 2V from vcc rail.
Pre-clip, I think that is too far from the rail (if so).
Perhaps you are developing a new smps for combo, well ... I hope it is not the same as ours ... eheh! Joke.
Regards,
Roberto P.
I think the THD vs power graphs tell most of the story. 420W at 4 ohms is the minimum distortion point but by no means the clip level: at 600W distortion is still 0.01% which isn't clipping by any stretch of the imagination. Clipping power (1% THD) is about 700W which is perfectly in line with the loaded supply voltage, 100Hz ripple and a few volts of headroom. A 2.4dB trajectory between minimum distortion and clipping might sound like a lot until you consider the alternative, which would be to use a fixed frequency amplifier. Such an amplifier, if it used a ripple-compensated modulator, could be designed with sharper clipping (i.e. minimum distortion is closer to the clip point) but that would mostly be because the clipping point becomes *lower* on account of minimum pulse width. With the same power stage you might for instance get low distortion all the way up to 550W at which point pulse skipping sets in and distortion jumps aggressively. Given the choice I'd rather have gentle clipping with a higher maximum.
I fully agree. Some additional questions:
- Can you say anything on distortion and IM at very low levels, say in the range from a few mW to 1 Watt as a function of frequency?
- Is the HF at the speaker terminals under load similar to that of the UcD, about 200 mV RMS at 400 KHz?
Thank, and Yes, I agree that thd vs. power you can see how the "engine". In fact, I asked the voltage of the PSU. Only one thing is not clear. it seems that measures 8-4-2R, have the same point on the ripple psu. this was my curiosity, since I know the psu unregulated.(or test with regulated PSU?) However, the measures have achieved great improvements over the traditional ucd700. Certainly, it would be interesting to test one.
Roberto P.
Roberto P.
This N-core looks like a real game changer for class-D amplification as well as giving all other amplifier classes a run for their money. For the first time you have efficient operation and ultra low distortion amplification even into low impedance loads !!
Well done to Bruno and the crew at Hypex. It will be interesting to see how these are accepted in the market place, because traditionally class-D has been something that was usually relegated to driving subwoofers or in professional PA applications.
regards
Trevor
regards
Trevor
@Javin,
If the analyser had two low-distortion sine oscillators and two notch filters I could do low-level IMD plots as well but now I have to use the AD/DA path. As you can see from the grey plots even at high levels the converters pretty much dominate the result so all I could do was to crank up the level until something showed up that was caused by the amp.
You can do an estimate though: because the loop gain is more or less constant up to 20kHz, IMD and THD behave very similarly and furthermore readings will be largely independent of frequency. Under these circumstances, mix products of a 1:1 IMD test will have about the same amplitude as the HD products of a single tone test. If you mix 18.5k and 19.5k, the 2nd order mix product is at 1kHz, the 3rd at 17.5 (and 20.5), the 4th at 2kHz, the 5th at 16.5kHz etc.
This is only conditionally true (only if you don't get thermal modulation effects or slew related distortion for instance) but it holds pretty well for UcD and Ncore.
From the THD FFT plots at 1W you can then estimate that IMD levels will be similar, that is around -110...-120dB depending on the load.
Anyhow, low level IMD does not do anything crazy. There are a variety of fields in audio where people postulate fancy low-level IMD effects that fail to show up with single tones, but I've yet to see that happen in reality. IMD is mostly interesting to characterize performance at high power levels.
@Roberto, the test was done with the unregulated SMPS1200. You can see this from the fact that:
1) 2ohm clipping power isn't four times 8 ohm clipping power
2) clipping power is lower at 100Hz than at 1kHz.
If the power supply were regulated the tail end of the THD plots would overlap exactly and power levels would scale exactly with load impedance. There's something like 10Vpp ripple on the supply at 1200W.
@Trev,
It would be nice to see this thing in a PA amp. Imagine that, audiophile live sound. I find that live sound engineers are sensitive to sound quality (albeit only after a number of practical requirements) so it might well happen.
@Trev,
Bruno, thanks for answering my questions. Seems to me that you have a winner here. With the (probably?) coming EU restrictions on power dissipation, class A could potentially become a thing of the past and your circuit may well be a key element for future high-end power amplifiers. I hope you can get international patent protection; could be worth a fortune. Good luck!
Hi Bruno
It’s interesting and nice to see that you have designed a new amp that is better than the UcD.
I have to agree in everything you are saying in the WP.
BTW: when you say that your new comparator is using 10 transistors, I guess that you don’t include the CCS’s, but only the comparator with the floating collector outputs.
BTW2: are you using one or two CCS’s in the comparator?
Cheers
S
Cheers
S
Bruno, I have a question comparing UCD versus N-core in a very specific loading configuration.
Generally using UCD to drive electrostatic speakers work fine except when driving the stats transformer so hard that the core starts to saturate which is actually not that hard to do. It looks like that the resulting very low loading impedance collapses the feedback taken from behind the filter resulting in the sound cutting out for a second or two in a rather nasty way. A regular class AB amplifier only starts to distort heavily but doesn't mute.
My question is will the N-core technology, which seems capable do drive much lower impedances, behave in a similar way or would it be capable to handle this better.
@stinius
Ooh you're trying to get hold of the fine details there. The comparator is a more traditional design compared to the old UcD one. Counting tail sources (two) it's 11 transistors.
@beun
The difference lies not in the feedback but in the way the overcurrent protection works. In many class AB amps the overcurrent / SOA protection just limits current. In most UcD modules and in the NC1200 it limits current (i.e. keeps playing with distortion) for about 50 to 100ms, depending on the signal. If the overload condition lifts before that, no muting occurs. If the overload condition persists, it'll mute for a second as a safety measure. In fact, you could disable the mute stage and force the amplifier to remain in the ordinary current limiting mode. I'm not comfortable giving instructions on how to do this, however, because some people might then try to drive our amps beyond their abilities for sustained lengths of time.
Actually the low impedance capability of the NC1200 speaks against doing this. The current limiter kicks in around 38A. Do you want an amplifier insisting on driving that amount of current into the primary of the step-up?
In short, the protection behaviour is not the result of feedback collapsing or any such thing but is done by protection circuitry that was explicitly added. The only thing I might consider is tweaking the overload mute timing.
@beun
- Class D
- Hypex Ncore
