Hypex Fusion bug and wishlist
I'm a bit concerned about the documented 'bump' on power-off. Maybe a relay that can protect a tweeter if not other channels (or otherwise can the amp gain once mains starts to collapse).
An optional enclosure, like the miniDSP ones.
Documentation so we can write a configuration tool that's less tied to Windows.
Document the protocol from the remote, so we can control from arduino or rpi.
USB audio.
Async USB audio with clock synch between two units.
Ditto ethernet for extra points.
i cant get any sound out of my sub.
i have a FA252
i have forced indput to S/pdif
make a filter with lowpass at 70hz
uploadet filter.
turn off my sub
connectet indput cable and turn it on.
no sound when played a sub test or any test on youtube.
so what have i done wrong?? 🙂
An option to disable unused inputs!
I'm using only two digital inputs and w/o display it is guessing how many times to press left or right on the remote. Disabling what is not used should be a simple enough fix, right? A (reasonably priced, very simple) display of course would also be great ...
Otherwise... this (FA123) is a truly spectacular amplifier! Thanks for the 3 channel option.
