hum
Hi all,
I have some problems with hum in a tube amp.
Hum is bigger when I turn volume pot to max volume, and when I plug a source in the RCAs input.
Hum is always seen as a 100 Hz signal in scope.
Ripple in PSU output is small, about 6V peak to peak.
Some help is welcome.
regards,
luis.
Sounds to me like diode noise (twice the 50Hz mains frequency). Also in my opinion 6V ripple is very high. I like something in the mV range.
Bottom line- I believe you need to make sure the rectifier(s) are well away from any signal lines and you need more filtering on the B+.
Edit:- I would also move the filament CT from your signal ground to the chassis ground.
Regarding your diagram It seems like it would work ok, but there are a few things I want to point out. To each his own, but this is just food for thought.
1) The heater center tap should have it's own line to the star ground, instead of being referenced to the input's ground.
2) How the volume control is setup is common for a guitars volume control. However; for an amp, the signal should be fed to the end of the pot(opposite end of ground, obviously) rather then the center. Then use the center to go to the input tubes grid. This workes like a voltage divider and prevents the signal source from being loaded down at low volumes. Also, the pot's ground should be connected to the ground of the input tube rather than at the star/power supply.
3) Your amps basically grounded at the star point. This is fine when using a signal source that is not referenced to ground(like a CD player) , but if the source is grounded(like a computer) you may get a ground loop. If you have a ground loop problem when using a grounded source, you hack the ground connectors off the RCA plugs at one end. Leave one end in tackt though so the shield in the cable is grounded still. Just you don't want to connect the two grounds. It's best to reference ground at the input rather than the star point. Though sometimes, it is difficult to do without causing ground loops, when using a single power transformer for a stereo amp, such as your case.
4) Also, it appears it already is, but in your setup, the input jacks should be isolated from the chassis. And referenced to ground through the cable sheild. If it's not isolated from the chassis and is also grounded through the cable that would cause another ground loop.
You may already get this concept, but it took me a while to figure out(im slow). Current returns to the transformer winding, ground is just for voltage reference. Once I figured this out, It helped me alot when coming up with grounding schemes.
Thanks a lot.
Sorry, I forget to say that is a PP amp with EL34 in UL configuration (30 watts)
PSU have 4 x 47 uF MKP caps (Mundorf Tubecap).
I have replacing CT-heaters to chassis ground and hum remains the same, but replacing RCAs GND or POT-GND are a huge difference.
I have 2.5 mV (rms) of noise at L channel, and 6.5 mV (rms) at R channel, L channel being almost inaudible now, and volume pot are no problem with noise.
I will try to add a 200 uF (electrolytic) cap to PSU (total 400 uF) and last with a total of 800 uF.
I will try different points to tie RCAs and POT-GND to ground in next days. I will be happy with only 1 mV of noise.
regards,
Luis.
Make sure your rectifiers are good also. In a push pull amp even 100uf in the power supply is more than enough to get the hum down into the mv range, so I don't think adding more uf will help much. Check the diodes to make sure they aren't passing AC.
Daniel
Hi Luis
Try this: from B+ make a voltage divider to get around 40 to 45 V.
Place 1 microF x 250V poliester from this point (40~45V) to ground.
Connect that point to the CT of the heaters (and of course disconnect the CT from ground...)
And say good bye to hum.... (well: in 99% of excessive hum instances it will be gone...)
And it doesn't hurt to use DC for the heaters' supply to the input stages....
Buenas sortes
Ricardo
I can testify to making a simulated center-tap on the filament lines. I had a preamp with a simulated hum of less than 1mV that hummed very loudly, then Sharon over at DiyTube referenced the filament to ground with a couple 1k 1/2 watt resistors and it's very quiet.
You will probably be happy with a bit more than 1mV of noise, I don't know for sure but pretty much anything under a volt or maybe 1/2 a volt for the plate is quite good for a power amp. One other thing I've heard of that you could try is "lifting" signal ground, i.e. making a separate star point for all non-PSU grounds, and connecting that to the PSU ground and chassis with a 10-ohm resistor. Making the signal ground "less negative" than power ground should block out hum from the PSU, or so I've read. I'm going to try it in the amp I'm building, so check back in a couple weeks, a month at most, to see 😉
danFrank said:
Make sure your rectifiers are good also. In a push pull amp even 100uf in the power supply is more than enough to get the hum down into the mv range, so I don't think adding more uf will help much. .
Daniel
Hi danFrank,
I used UF5408 diodes (ultra-fast) with 0.1 uF mkp in parallel with each diode.
I agree with you that 200 uF could be enough for low noise.
danFrank [/i][B] Check the diodes to make sure they aren't passing AC [/B][/QUOTE] I suppose you want say DC. mmm... interesting. I will test it. [QUOTE][i]Originally posted by danFrank said:
Thinking about it some more, I would thnk your problem lies with a ground loop. Usually hum doesn't increase that much when the volume is turned up with a power supply problem; it's VERY loud all the time!
Daniel
Surely. At the moment, I replace some GND points (RCA and Volume POT) and noise is lower and is the same when Volume POT is moved.
This was a huge improvement.
I think the same, noise is greatly caused by ground-loops or a bad 0V reference point, when hum arises with volume turned up, things seems clear to me that there is an earthing issue.
cheers,
Luis.
bembel said:
Hi, to me 6Vpp is a lot too !
Jed's remarks are very pertinent (is your CD player three or two connectors plug to mains ? ----> ground loops)
Have a look at this, it may be helpfull ---> http://www.tone-lizard.com/High_Resistance_Ground.htm
Do you see any difference tightening inputs/outputs cables together? (thus reducing ground loops on interstages cables)
Hope it may help.
Great article !
thanks.
rwellerson said:
Hi Luis
Buenas sortes
Ricardo
Hi Ricardo,
Ouch! I forgot the good old methods.
I have not a voltage divider in my PSU, but I have cathode bias at EL34 (with a resistor), with 33 VDC at cathodes and I could tie CT filaments at this point.
It seems a good advice.
Thanks Ricardo!
Luis.
LuisMCP said:
Hi all,
regards,
luis.
Hi all,
Further investigation about the matter give me a new point of view, I saw that my amp had three kind of noise:
1) Ground Loop hum.
2) High frequency noise
3) Some noise of ripple from PSU.
1) Was eliminated first day, when i reconnect RCA grounds.
2) This noise is done in PSU and snubbering is a must. I use an RC network to lowering this noise.
3) Was located at phase splitter stage, and mismatched output tubes makes things worse; it could be fixed with more filtering in
voltage amplifier stages or using a voltage regulator. I have to try these in next days.
In the meantime, I am not shure how good mains transformer is, when I have measured these numbers:
Ls (leakage inductance at secondary) = 23 mH
Cs (leakage capacitance at secondary) = 1.21 nF
Total Copper Losses: 16 watts.
Total Iron Losses: 9 watts.
Efficiency: 90%
I would like to know if you have measured your mains transformer, for comparation.
It seems that Ls and Cs are very large.
Regards,
Luis.
