Hi Guys,
I have to offer a surplus of high quality Insulated turret terminals, ceramic and teflon insulated. I've had these for years and done nothing with them, so time to re-home them to others who do need them.
These terminals are for chassis mounting, in point to point amp/pre-amp builds.
High insulation is provided by the ceramic and Teflon materials, so these are especially good for high voltage valve/tube projects.
They come complete with screws suitable for use on approx 1.5mm-3mm chassis thickness, which should cover most DIY needs.
The ceramic insulated type have silver plated double turrets. Terminal height is 16mm (without screw)
The Teflon insulated type have a pre-tinned double turret. Terminal height is 18.5mm (without screw)
I have ~300 of the ceramic and 80 of the teflon available
Price for either type is GBP20 for 40 pcs, including mounting screws (= just GBP0.50 per terminal, a bargain)
Postage per lot: UK GBP2.00, Europe GBP4.00, Elsewhere GBP5.00
Payment accepted via Paypal
Such nice quality turrets are getting tough to find, especially at a very good price, so act quickly to avoid disappointment!
Please leave a message here in the thread and send a PM with your request if you'd like some. I'll get back to you asap confiming availability and total.
Rob
Rob
OK Mark, most welcome, PM sent.
Plenty of the ceramic, and aprrox 60 PTFE, are left at the moment..
Hi guys,
I have just one lot of 40 of the ceramic turrets available due to a non-response.
Who would like them?
Cheers
Rob
Cheers
Rob
