HP3562A and KE5FX plotter emulator
my HP3562A works fine with a real hardware pen plotter HP7475, but not with the KE5FX plotter emulator.
The hardware plotter only works with a given adress for example 3) , but not in "listen only" mode.
I tried every setup with the plotter emu, but the transmission will always stop after a second or so. Then the 3562 goes from talk (flashes for a second) into listen mode. The emulators "collecting data" counter count up to 20 byte or so....then it stop and jump to zero again. Also tried the recommended HP plotter address "5" without success. All my ohter HP analyzers wotk fine with the emu.
The 3562A is listet in the partially supported devices, and i found pictures (plots) from the 3562A and this plotter emu in the internet. Did i miss anything?
