How would this work out?
It can't, they were (ahem) smoking something when they wrote the description.
What they intended to write is a false representation of the output of the lamp at 151,000 lumens. The lamp puts out a beam rather than being an omnidirectional point source, and the lumen number takes into account their reflector. While perfectly good for growing pot, the optics of the reflector make it somewhat questionable for projector use.
To answer the thread starter's question: It may be possible to get an even picture out of a PAR or ellipsoidal bulb, but you're gonna need to do some experimentation to find out. These were designed for lighting, not for projection. Integral ellipsoidal reflectors form the bulk of lamp designs for commercial projectors, but they're specially designed short arc beasts of a different color.
Make sure that you don't skimp on the cooling, though - aluminized glass like this (unless it's marked dichroic) reflects heat just as well as it reflects light.
