How to roll off LF on B&C 12-inch woofer
Using the well regarded B&C PE32 12-inch woofer in a mid-bass application with my Stereolabs horns.
B&C 12 PE32 is a 12" high efficiency mid-bass woofer - B&C Speakers - B&C 12" high efficiency mid-bass speaker for 2 or 3-way systems. B&C 12 PE32 high efficiency mid-bass speakers available now.
Aim is to run this driver from 80Hz to 500Hz in a sealed box, approx 60 Liters (2.2 cubic foot).
Will use separate amp to set volume for the driver.
I have coils to take care of the top end, eg 500Hz.
What's the best way to manage the LF below 80Hz....? The Thiele-Small specs refer to a coil inductance of 1.2mH...is this related to the low pass?
Regards.
Andrew.
