hi everyone out there.... I have this problem with my new build 50watt mono block power amp, whenever i switch on the power of the power amp, it give me the loud hum sound... the hum sound will gone off after i turn on the input signal source (CD Player). Just wana know how to remove the hum sound before turning on the cd-player??? Thank in advance for any helpful information. 🙂
hum
You can solder resistors from hot to ground on your inputs.
I think the values should be in the range between 10K and 47K.
good luck
Arne
good luck
Arne
Re: hum
finally sloved the problem... but the values range u gave me doesn't work for my amp... so i use a variable resistor & found out that a 2 ohm resistor value work best for me... Thank for ur idea! 🙂
yeti said:You can solder resistors from hot to ground on your inputs.
good luck
Arne
After added in the 2 Ohm/3w Resistor the hum sound has gone, abt the sound i think it still the same only the input signal volume has slightly lower....
hacknet said:2 ohms? u are drawing more current from that resistor than the speaker is....
drawing more current? abt this i not too sure coz i am only a newbie in diy audio.... but the amp itself already hot wired a 15k ohms between the input signal and the ground, so i actually added in another 2 ohms resistor in parallel....
the 15k is the input resistance, by u putting a 2ohm resistor across, u are almost shorting the damn thing, u want to becareful not to short up the preamp`s output stage. i thing u should take out that 2 ohm resistor and resort to something else.
simple theory,
(R1*R2)/(R1+R2)
eg:
(15k*2)/(15k+2) = 30k/15k002
= 2 ohms
becareful.
if u have 2volts into the inputs.
V=IR
therefore
I=V/R
I=4/2
I = 2 ampere.
u are certainly overdriving the preamp.
since u are in singapore, give me a call at 62812827. lets see what we can do.
REGARDS
simple theory,
(R1*R2)/(R1+R2)
eg:
= 2 ohms
becareful.
V=IR
therefore
I=V/R
I=4/2
I = 2 ampere.
REGARDS
- How to remove hum sound?
