How to obtain low dc offset at the Aleph amp output?
Thanks guys! You have helped me to be confident enough to order the parts for an Aleph A3 tomorrow. Will use a 18Vac x2@12A transformer, 4kg heatsink for each channel, 800mA quiecent current on each IRFP244, 40,000uF on each 25Vdc rail. Will add a speaker protector as well. Any further advise before I take the plunge ?
Input capacitance is about 2x that of IRFP240 or IRFP244. On the other hand,
it is a bigger part...
Looks like you want to run 1.6A current, so about 40W dissipation. I think
ZenMod uses a single IRFP150 in his Babelfish-J (in the thread he linked above)
so you should be able to do the same for the Aleph-3.
If you're going to just use IRF9160, an alternative part to consider is FQP3P20.
Do bear in mind that the MOS-FETs need to be matched. Not all together, but each CCS and Output set need to be carefully matched. This might take 5 x or more of the final quantities required to achieve. Even devices from the same batch can vary wildly.
Here are some notes that I recorded a few years ago. Some of the numbers might be a little off, but they provide a pretty good guideline.
Power transformer's VA rating needs to be 7.5x channel output power for each channel
per channel:
a40 24v 300va (~30v rails 40wpc output, 100w heat dissipation
Aleph 2 35v 750va (~45v rails) 100wpc output, 300w heat dissipation
Aleph 4 35v 625va (~48v rails) 100wpc output, 250w heat dissipation
Aleph 5 26v 300va (~34v rails) 60wpc output, 150w heat dissipation
Aleph 30 20v 250va (~25v rails) 30wpc output, 100w heat dissipation
