Hello,
I'm making a pre-amp+power amp unit which goes in to a speaker box (active speaker). The input connector is in back panel and I want to have a volume control (pot or rot switch) in back panel too. The problem is that the back panel is 40cm away from pre-amp.
- It would be easy to wire the input connector to pot and use it as an attenuator. But then I have to increase the gain. No good.
- If I use opamp in pre-amp as a volume control, I'll have 50+50cm wiring and it might pick up noise. Right?
Now I'm thinking to have a digital potentiometer in preamp and control buttons in back panel. Any other ideas?
Thanks,
Tipo
Thanks,
Tipo
LDR
Maybe You could use a ldr and a led with a potmeter in series .
Cheers Rens
Hello,
Thanks,
Tipo
Cheers Rens
mount/solder the pot on the pcb of the preamp and then use a metallic or hard plastic cylindrical thin rod to transfer the rotational motion from the back panel to the pot.
+1. Put the pot where it should be. Extend the shaft as needed.
