Hello EveryBody!
Today, I would like to go back and continue the Topic of "How to make a table saw" that I mentioned under the link:
http://www.diyaudio.com/forums/equipment-tools/283882-how-make-table-saw-video.html
Today, we are going to make the components supporting table saws include: spliter, guard, anti-kickback paw.
I have made a video describing the process of making the components above, you can see here:
https://www.youtube.com/watch?v=Qx71G7ouIeI&list=PLZsZGQzjaz9XxNbcMMtW-V7ykFMA4y4oz
https://youtu.be/f2mWQea2S30
Step 1: Make the Splitter.
You need to use a plate steel with size of about 200mm x 300mm x 2.5mm, then used the saw to cut steel plate under the parasols and the desired shape.
Design your spliter core holding Guard and anti-kickback Paw.
Step 2: Make the Anti-kickback Paw.
You continue to use the plate steel to cut the line with two-dimensional shape with serrated saws wood downwind. The wood-aliasing helps embryos move in one direction only, to avoid being shocked by the impact of the blade.
Step 3: Make the Guard
You can use the Mica (Acrylic) to make Guard, make sure that increased aesthetics. Here, I use about 8mm thickness Mica. Guard has been designed to be able to latch mounting Splitter easily
Step 4: Assemble the parts together and inserted in table saws.
I used screw types to link the components together and paired with table saws. Split tongue is attached to the saw table through a right angle and easily removable fasteners through.
Step 5: Complete and enjoy the results.
Wish you happy, and one day work efficiently!
