how to id transformer VA
I have a number of center tap 120v transformers and while secondary voltage is easy to determine how does one determine the current limit? Second does each channel of say a chip amp require a dedicated PS? and in my case with active x-over can i supply the three amps for that single channel with a dedicated power supply, I would hate to have to build 17 seperate powersupplys for this project! Third all chips being used require +-15 v, need i replicate these for each chip or channel. thank for any help
No need for dedicated PSU. Most would prefer it, but cost gets in the way.
Do you know the watt rating of the trafo? W/V=VA.
Edit: It's good practice using a (or two, +/-) voltage regulator for each chip and mounting them close to the chip. The filter caps before the regulator(s) can still be shared.
thanks
regretfully the transformer came out of an old amp. large toroid rectified to + -45 volts but no markings to suggest wattage?. on the ps for the chip amps i had a brain fart am using the +-15 v to power the crossover section sorry.
