Does anyone one need PCB? Let me introduce a good supplier in china
Huanyu Technology Co.,LTD. has an annual output of precision single-sided, multilayer, HDI, metal substrate and FPC boards more than 1.5 million square meters,
*Head office in DongGuang over 20 years of experience
*For your order our production capacity is very strong .for employe over 7,000. Three factory another two for Shengzhen and DongGuang
*The productiviy of more than 150,000-250,000 square meters/month/factory
* During the past five years, sales volume has increased more than 30% annually. 2011 annual sales was0.75 billion yuan, annual sales exceeded 0.9 billion yuan in 2012, expected 2013 annual sales up to 1.5 billion.
*The clients come from all over the world, we have provided quality service for over 30 countries.
FPC Parameter
Tapes of FPC: single-sided,single-sided hollow-out board,double- sided,double-sided boards, 3~6 layered board,Rigid-Flex PCB
substrate copper thickness of FPC: 8um 12um 17.5um、35um 70um
Min line width/space: 2mil/2mil
Min width/space: 4mil(0.10mm)
Min mechanical drilling hole diameter: 500mm X600mm
Surface Finishing: ENIG,Immersion Tin,Immersion Sliver,OSP,Gold Finger Plating,Tin Plating,Whole Panel Plating
HDI Parameter
Tapes of HDI: 1+N+1 HDI,2+N+2 HDI,3+N+3 HDI,Arbitrary
Min line width/space:2mil/2mil
Min mechanical drilling hole diameter: 8mil(0.20mm)
Min liser drill diameter: 3mil(0.075mm)
Blind hole's Aspect Ratio: 1:1
Surface Finishing:
High-Multilayers Parameter
Layer Count: 36
Meterials:Hologen-free materials ,PI Materials,BT materials,ppo,mixed compression,high frequency (Roger、 Arlon\Taconic、Nelco、 Taining,Microwave F4B,Isola...)
Min drilling hole diameter:8mil(0.20mm)
Max Aspect Ratio:6:1
Max finished boare size: 23″* 32″(584mm*812mm)
Surface Finishing: Lead HASL,Immersion Gold,Immersion Tin,Immersion Sliver,whole panel plating, OSP,HASL,Hard Gold plated,Gold Finger,and mixed surface treatmeat.
Color of Solder Mask: White,Black,Yellow,Red,Green,Matt
Special Technology: High-frequencry mixed compression,back drilling,Press fit hole,metal substrates,buried capacitance technology and buried resistance technology
HDI PCB ManufacturerPCB Fabrication
pcb prototype Express PCB
Rigid-flex PCB Supplier
Flex PCB Aluminium pcb
FPC Parameter
HDI Parameter
Surface Finishing:
Layer Count: 36
