How to drop voltage for a TT motor?
vintage Dual turntables are driven by synchronous (or asynchronous, depending on the unit) motors with dual windings that can be series connected for 220-240 Vac use or in parallel for 110-120 Vac - at least unless the TT comes from a Dual integrated console, containing the amplifier and sometimes a radio. These TT's are fed from a 150 V tap of the unit's mains transformer - for whatever reason. So the motor's winding is designed for this supply.
Sometimes we want to use such TT's as stand-alone units, so the voltage has to be adapted. We could use the console's mains transformer, which were a bad solution, due to it's weight and inevitable magnetic stray. Now voltage dropping comes into mind.
I'm aware of the complex nature of the load that a motor presents, consisting of the winding's inductance as the reactive part and the resistance, in series (or in parallel?) with the mechanical loading, as the real (ohmic) part. How can I discern between both in order to calculate an appropriate dropping resistor? Is even a dropping capacitor (in order to minimize loss) possible? How would I calculate this one?
To give you some information: In the datasheets of their turntables, Dual usually tells 10 watts as the motor's power consumption.
Best regards!
Jon's capacitor may work fine.
Depends a lot on the motor details.
I have seen a series cap (on a non-sync induction motor) RAISE the speed and power consumption. The cap resonates with the motor inductance. A Synchronous motor "can" be "tuned" to act inductive, capacitive, or resisty- but that requires adjusting the Field current, which is not an option on tiny sync motors.
Actually a "sync" motor this small may not be a full Synchronous machine, but a salient-pole induction motor. Which will be inductive. In this size, probably a large resistive component. Which will tend to damp any L-C resonance, but in my work with a 43W motor, not enough.
I have had fine results (every time my furnace runs) with a simple resistor.
10W @ 150V is 0.066A
230V-150V = 80V drop
80V @ 0.066A is 1,200 Ohms 5W (use 10+W)
Certainly a handy 1K 10W is a quick and safe thing to try.
Finally a split-primary 115V+115V:36V 10VA transformer can be cobbled-up as a 230V:151V auto-transformer.
I'm aware that reactances of capacitive and inductive natures are of opposite phase. So the voltage over a dumping capacitor will exceed the mains voltage by the value of the voltage the motor's inductance sees. To do relilable math, I'll have to determine/measure the motor's inductance and it's ohmic resistance under load. How to do this?
Even calculating the exact value of a dropping resistor needs knowledge of the inductance's value.
And as said before, I'd want to avoid any transformer.
Best regards!
The main claim of a synchronous motor is that it is NOT critical about its voltage.
If voltage is low, it will run weak. If voltage is high it may run warm.
It is likely a well-stocked junk-box can get you a trial value faster than thinking.
