I have some drivers that apparently have the proper specs to be used in an aperiodic box.
There is already a sealed box design for these drivers, so how would I translate this existing box to one that uses an aperiodic vent? Can I just put the aperiodic vents in the box and then try to tune it via the filtering, or do I need to adjust the size of the box as well?
After searching through the forums, I found some good information describing what happens with an aperiodic vent, but perhaps I don't know enough about speaker design to translate this into a box.
Any help would be apreciated.
Thanks!
KT
Thanks!
KT
