How to correctly AC ground the negative input of a RCA input?
Hello everyone,
I would like to ask you to point me in the correct direction. I am building a class D amplifier utilizing the TPA3128D2. In the datasheet I have read that "To use the TPA31xxD2 with a single-ended source, ac ground the negative input through a capacitor equal in value to the input capacitor on positive and apply the audio source to either input.".
Which one of these is correct?
Thank you.
