How to convert a 100V SMPS to a 240V one?
If the SMPS is built for 110V operation without and option for upgrading, its difficult to change the input voltage range.
you will have to change the MOSFET, Input filter components.
Even change the transformer windings for better efficiency.
jtkraj is absolutely right. In SMPS, all the parameters are tightly calculated and applied and hence changing any parameter may not give optimum result if upgrading modalities are not included. Even it may hamper proper functioning.
Thanks.
