I purchase one topping amplifier and receive today.I just want to know how to connect it with mp3?Can it support this function?
One of these will do it. You can find them at Walmart, Best Buy, etc.
http://http://www.newegg.com/Product/Product.aspx?Item=N82E16812200418&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
If the Topping has a 3.5mm jack, you can also use a 3.5mm to 3.5mm cable. readily available at Walmart, Best Buy, etc.
Mike
Mike
This one: TOPPING TP21 - NEW TA2021B 2*25W Class T Amp Headphone Amplifier+14V4A AC power adapter
Exactly I have not purchase yet.My friend told me that it may not support mp3.So I want to make sure that if this amplifier can connect with mp3.I like the appearance of it,so cool and has a light weight.Is there any one used it before?
It is an amplifier. It amplifies an audio signal to play on speakers. I have no idea why mp3 is even relevant to mention? Is your friend perhaps in a special ed class?
Yes,Saturnus is right.And it is actually can connect with mp3.The way is:use the mp3 as voise source.Then connect [FONT=宋体]3.5-RCA with mp3,and the other one connect with the amplifier.It is done without any effort.[/FONT]
Thank you,Saturnus and Lucywy.then I am sure about it.Now I just want to know the tp20 Topping TP20-MARK2 - TA2020 Class T Digital Mini Amplifier +14V 4A AC adapter
and tp21 TOPPING TP21 - NEW TA2021B 2*25W Class T Amp Headphone Amplifier+14V4A AC power adapter
I like these two pieces,but I have limited money.So can you tell me which one is better?
According to my experience,this one TOPPING TP21 - NEW TA2021B 2*25W Class T Amp Headphone Amplifier+14V4A AC power adapter.
As the chip is better performance and it with headphone as the price is only $6 more than tp20.So my advise is tp21
- Class D
- How to connect topping amplifier with mp3
