Hello all,
i am building a set of PLLXO (line level passive cross overs). They will be put between two B1 buffers. The PLLXO's are second order at 2000Hz. The system is modular so i can also switch to 3000Hz for other speakers.
I want to test the behaviour of these cross overs to see if they really give a cross over point of -12db at 2000Hz. I could use signal processing software. But which is the best software to do this? And i am thinking of a white/pink noise signal to get the complete frequency band. Any suggestions?
regards
regards
