Hi all,
I have a Project RPM1.3 that came with stock Ortofon 2m Red cartridge. I bought a Denon DL110 but have little to no experience in changing cartridges. Any advice would be most welcome
I think the mounting holes on the Ortofon are threaded so you will need some longer bolts plus nuts and washers. I think M3 or #4-40 is what you want, but verify that. I assume the Denon comes with mounting hardware anyway. I assume the turntable came with an alignment jig of some sort, if not go to vinylengine.com and download and print a template. Alignment is the only tricky part. Then balance the arm an dial in the VTF.
Thanks!I think the mounting holes on the Ortofon are threaded so you will need some longer bolts plus nuts and washers. I think M3 or #4-40 is what you want, but verify that. I assume the Denon comes with mounting hardware anyway. I assume the turntable came with an alignment jig of some sort, if not go to vinylengine.com and download and print a template. Alignment is the only tricky part. Then balance the arm an dial in the VTF.
