How to cascade 2 ADC chips?
Pardon my noobie question.
I would like to build an 8 ch ADC using two pcm4204 chips (24-bit 4 ch ADCs).
Would it be correct to use 1 chip as a master and the other as a slave?
In such a case, the slave chip should receive only the BCK and LRCLK from the master chip (no SCKI), right?
The crystal XO should feed only the master chip SCKI, is it correct?
Thanks.
