Apparently my speakers survived 300mV (!) worth of it. The other channel had around 90mV. This is coming from a cheap small Chinese ebay amp that hums like crazy.
So I was calculating, at 0.3V, the heating power would be, assuming 6 ohms for DC current, 0.015W, which appears to be able to generate less temperature difference than living in the tropics, which I do.
Do we need to be paranoid about speakers frying from such (huge?) amount of offset? 😕
I think it's more indicative of a flaw in the amplifier at these sort of levels than of actual concern for the drivers.
It may damage the transformer of a direct coupled ribbon tweeter, but you should never do this anyhow. The offset could also degrade sound quality I suspect.
You'll get lots of opinions about how much offset is acceptable, but if you have 300mv there is something wrong with the amp.
Generally, most DC protection circuits dont kick in until the DC gets above 1V, and your math is correct.
Best, Bill
Best, Bill
Had a DCX2496 leave 1V DC on one of its outputs(it was faulty) into a Zapsolute mk2. It's DC servo probably saved things but even that ran out of range.
Peerless HDS164 (850438) got HOT!
I first detected a smell out of the BR port and turned things off quickly. It was on for a minute or so, maybe two.
The phaseplug was nearly untouchable and the cage was nearly as hot.
The driver works fine and I can not detect any differences or bad sound compared to the non heated one.
So it depends on the driver. The thermal design is important and they certainly held up in that department.
Personally, anything above 50mV is a no no. Prefer it to be under 20mV.
More due to principle than damage potential.
David_Web said:Had a DCX2496 leave 1V DC on one of its outputs(it was faulty) into a Zapsolute mk2. It's DC servo probably saved things but even that ran out of range.
You had a hell of a lot more than 1V DC across your speaker!
Bill
I sure did.
No way of knowing how much as I don't know the gain of the amp nor how much the DC servo managed to correct before 'clipping'.
I was afraid I had burned both amp and speaker. But they are fine.
I guess this is why we pay for quality.
Hi,David_Web said:No way of knowing how much as I don't know the gain of the amp nor how much the DC servo managed to correct before 'clipping'.
if a DC coupled amplifier is a "must", then one "must" consider DC detect and speaker isolation. A DC servo is NOT ENOUGH.
Loudspeaker and DC Offset
I readed some very short about this here:
B&C SPEAKERS
But I would like to find something more specific(theorical analysis I mean!) for that....Do somebody know where I can find something like that???
Opacheco.
B&C SPEAKERS
Opacheco.
The B&C paper refers to DC offset caused when driven with heavy bass content. That is, it is about the temporary shift of the mean position that comes with strong LF drive. This "DC rectification" is due to nonlinearities in the woofer such as inductance changing with postion.
I think the primary concern with DC is heating of the voice coil and loss of excursion from shift of the mean position. If both are minor then it isn't a real issue. The OP calculations show a minor amount in this case.
I have seen (and conducted) tests where some DC offset is intentionally applied to find the lowest distortion point on a particular woofer. You can generally null out even harmonics (at least at a particular drive level) by applying a little positive or negative DC offset. This can vary from sample to sample of a given design due to the difficulty of getting the voice coil height exact.
In extreme cases of offset the coil will come out of the gap and the cooling effect of adjacent metal parts will be gone. The coil can then fry in short order. Upon disection you may see one end or the other of the coil charred, while the other end is fine.
David S.
David S.
Agree that DC heating is the big worry. I'd think most VCs should be able to take half to one watt for some time without damage, or they'd burn up playing loud rock. Assume 5-6 ohms DCR, I'd be worried over 2 VDC, but it's all WAG.
- How much DC offset does it take to kill a speaker?
