how much can they take
recently acquired a pair of sansui sp x7 speakers in excellent condition. I'm driving them with a nad 3140 preamp and nad 2140 amp in bridged mode with a denon avr-95 receiver's preouts. Geuss my question is can these take this kind of power without destroying the speakers? Seem to sound good and clean but i am nervous about blowing them so i haven't hammered on them real hard yet.Any suggestions and/or advice would be greatly appreciated!
my only problem with that is they dont seem stressed at all. I,m used to how cerwin vega,s sound just before the flames!As i currently own 4 sets of vegas and have owned 9 sets totall.these sansui,s just seem to take and ask 4 more.Are these even really that good a speaker or am i comparing them unfairly with the dead sounding vegas that i,m learning to dislike alot.I really don,t want to ruin these speakers cause of a hard lesson or cause i wouldn,t listen to some advice as these same amps have sent several loudspeakers of todays caliber to the bone yard. thank you for your time and insight on music and not noise.
Hello. Probably you have read the power rating on the plate , which I presume is very low . Don't worry ,be happy ! You'll stress less your ears . BTW You can take a look at the inside , carefully , be careful with those screwdrivers near the cones , and if you want a 2-5 % improvement in sound quality , change the capacitors to new polypropilene types .
The only information I've gathered from the web is this (from audiokarma):
"The Sansui SP-X7 Speakers were manufactured from 1978 - 1980
I have a set in near perfect condition and I love them (owned them since new in 1978). However, they are more of a rock / hard rock speaker than jazz / blues. Bottom end is lacking A LOT compared to my Original Advents, but top end screams. I always use this example: OZZY on the SANSUI; STEELY DAN on the ADVENTS."
So ,there you are: power doesn't come with quality , and viceversa.
Bye
I also agree with everything you mentioned about these speakers.I bought these for $50.00 and they also were in near perfect shape.I'm actually not real positive that they are blown since all the highs and mids in both speakers don't work now no matter where you set the switch.I'm hoping not since these had beautiful highs prior to their demise.Oh and i was listening to metallica one with the bass on the amp at 0 and treble at 3/4 with no distortion or popping.Everything simply just stopped working except the woofer's.Any suggestions would greatly be appreciated.
Sad sad sad!Same occurred to my vintage Kenwoods , same age , same price ,same damaged mid-treble. Luckily the drivers were double on every cabinet , so I arranged to make them work in a 16 Ohm configuration , using two amplifiers and an electronic crossover . I would follow Glowbug's advice , i would be tempted to buy planar tweeters...
A first check at the crossover to calculate the predictable crossover frequency , and the choice of drivers would be done in few minutes.
Bye
