I would like to ask you something more regarding the Isobaric enclosure size.
Is there a rough thumb rule to determine what will be the approximate size of isobaric enclosure for either a pair of 12" 8 ohms or 8" 4 ohms woofer for using in a small hatchback car? The mentioned woofers are Indian made (Milton) but there is not much technical specification from the manufacturer accept for the impedance and watts.
I am from a remote mountain called Nagaland where ordering or buying reputed international brand subwoofer is not possible. Also there is no help nearby.
Awaiting your suggestions please.
Chub2
Chub2
You will have to measure the Thiele-Small parameters of the drive units then design an appropriate box. You can measure the important ones yourself with a good soundcard, amplifier, millivolt meter and a couple of resistors.
