hi how do i get water droplet like finish on the surface of a pro audio speaker , i have heard that some manufacturers use acrylic liquid
this is the finish i require
http://kingblossomguitars.com/wp-content/uploads/2012/01/Water-drop-finish.jpg
or similar
Thanxs
or similar
Thanxs
Apply base coat, clear cost and allow to cure. You can then bulk up the "solids" in the clearcoat by allowing the solvent to evaporate a bit and "fleck" with a coarse brush. Cure the finish with some gentle heat. Practice
Speaker Cabinet Coatings | Texture Coating for Speakers | Road Cases Protective Coating
and you'll find many youtubes showing how to
apply polyurathene using spray gun! Before apply using polyurathene be careful with the quantity of hardner while mixing ìt! lowering the air pressure of the spray gun you can create a water drop texture on your speaker enclosure!
