If i have MLTL i like.
How do i fold it?
I understand that the volume should be the same and that the c/c of the driver and port should have the same distance from the top and bottom inside.
But what about the length?
And can i place the port on the side or even one on each side?
How do i fold it?
Adding the bend will add some length to the line, getting it right can be a bit tricky.
A fold will also add another LP filter to the line (not a bad thing), but leaving out corner reflectors (recommended) means the box will be a bit bigger volume.
As long as Zd and Zvent remains the same you can put them on whatever side you want (ignoring differences in room loading).
Here is what i ended up with when i folded the Woden ML-TL into a shorter/deeper form so that a seperate midTweeter box placed on top would be at an ear level.
http://wodendesign.com/downloads/Woden-A12pw-MLTL-plan.pdf
http://wodendesign.com/downloads/A12pw-folded-ml-tl-extents.pdf
For some reason i did put some deflectors on the folded line, probably for bracing and with the fold at the top pushing the volume up too much.
dave
dave
