How do i build a 12v power supply ?
i need a 12v toroidal power supply no more than about 5 amps max, to power my valve preamp. how do i build one or is there somewhere i can buy one ??
You can get 12v linear power supplies online cheap but they will have EI transformers 🙁. I'm in need of a 12v 5A PS with a torroidal or pot-core transformer as well because I need to have the lowest radiation and toroidal and pot-cores emit less radiation , I've looked extensively online but I cant find anywhere that sells PS's with torroidal or pot core transformers.
Does anyone where you can get one in the US? Or get them built at a reasonable price?
cheers Dom😕
Does the 12V need to be regulated (how tightly)?
Why does it need to use a toroidal transformer?
You may want to read this article, especially his comments on toroidal transformers:
http://sound.westhost.com/power-supplies.htm
And here's a power supply project
http://sound.westhost.com/project77.htm
I believe it does, I'm not sure how tightly (I'm still somewhat of a newbie at
all this)
Thanks for the articles the main reason I want it to have a torroidal transformer is because of the lower magnetic fields and better power efficiency.
If I had the time I would definitely dedicate time to learn how to build one it doesn't seem to difficult except for maybe the chassis, but unfortunately I won't have time at least until January.
12V and about 5A calls for a 60W NV halogen bulb transformer. They are (at least here in Germany) usually toroids and quite cheap...
PS. Of course this is only the transformer then, needs rectification and voltage regulation too, but this is not very difficult.
Using a computer-PSU requires modification of the regulation circuit because nearly every of them weights only the 5V-Output or it has at least the highest priority.
No load at 5V will result in a Voltage around 10,5V at 12V output.
(I'm running a carhifi-Amp on a omputer-PSU)
