Hello 🙂
i have a technical induiries please
I would know what caracteristics i must see in a bipolar and mos-fet transistor to have the better sound ?
Can you explain me that please? because in the datasheet there is a lot of think that i don't understand except the main vceo, vcbo etc...
And why old amplifier have a better sound like tube amp (i see a post who talk about that but i need more information 😱)
i have an old etage amp for a guitar with one "T03" MJ4502 and one "T03" Mj802 and the sound is great 😱 do you think T03 transistor are better ?
Thanks for your help🙂
how choose a transistor to have a better sound
Well a transistor doesnt have a particular sound it is determined by the circuit around it.
although a higher Tf (transistion frequency) and lower internal capacitances (see datasheets) alow the device to preform better in high speed circuits
I renectly build a headphone amp with 50 year old sluggish germanium transistors but it still sounds fine.
And the case of an transistor doenst determine the sound either it only makes a difference in size and heat dissipation.
T03 stile transistors can dissipate alot of heat but the are large and difficult to mount and isolate from each other.
The fact that old amps sound good or different is entirely determined by the circuit topology used in that time period
circuits are different now and have become more complex and better so al kinds of distortions have been minimized and thus the sound changes.
Greets captain archer🙂
In most solid state amplifiers, significant negative feedback is used and will compensate for differences in transistors, making the transistors generally irrelevant as long as they can withstand the operating conditions (current, voltage, power dissipation...). In effect, you get out of the amp, precisely what you feed into it (as far as sound quality is concerned).
For most solid state amps, you could insert a low value resistor (~2 ohms) between the output transistors and the speaker terminals/load and if the feedback for the amp was taken at the speaker terminals (beyond the resistor) the amp would sound precisely the same. Only the power output at clipping would vary (slightly lower with the resistor in the circuit). If you had that same circuit but took the feedback from the transistor side of the resistor (instead of the speaker terminal side of the resistor), the amp would sound significantly different. The negative feedback cancels most of the differences that most of the devices in the circuit can introduce. You could try 100 different output transistors and if none caused any serious problems like oscillation or crossover distortion (due to improper biasing), they would all sound the same.
Tube amps use little or no feedback and many things (transformers, tubes, biasing...) will effect the sound. You'll even find that some tube amps sound great with certain speakers and not so good with other speakers. Tube amps are very different from solid state amps.
Perry Babin is right tube amps are different
and remenber in a tube amp the transformer is the thing that colors the sound the most, especially if there is almost no feedback apllied.
and in a datasheet you could also look for noise factor in DB (how much noise an transistor generates) so if u use them i a low noise situation like a phono correction amplifier, the noise of the transistor wont interfere with the already so small and teeny signal that the phono element gives.
and one other thing is that tubes age and there characteristics change with age and thus the sound changes with it.
Transistor in genaraly dont age at least there specs dont change with age so after 30 years of use a transistor will still sound the same as it did when it leaved the factory.
greets archer🙂
greets archer🙂
hello
Thanks for your explaination 🙂
This is a photo of amp for guitar with a great sound that works well with any type of music from elvis presley to rap or techno music "with elvis is great 🙂"
I think to use it on my smps for a car audio amp 🙂
but i need to change some components because there are old
we can see 4 little transistors 2x BD529 and 2 who have 3 code color (purple, red, white)
i don't know if i can find substitution 😕
Have you got an idea please ?
Thanks 🙂
on the pcb amp i can see this code: 410CST1241 ELKA
i don't know who manufacture this amp for guitar 😕
Thanks 🙂
The three colours are the underside of the transistor 🙂 The type number is on the top.
Substituting the semiconductors will not alter the sound at all and the circuit may actually rely on the (relatively) poor HF performance of the outputs for example to help maintain stability.
Thanks Mooly 🙂
Yes i unmount the transistor and his number is MPS U57 😕 i don't know this transistor
for Substituting the semiconductors i prefer not for changing the sound of the amp just because they are old and i prefer new components 🙂
have you got an idea to change MPS U57 and BD529 please 🙂
These are old devices... the MPSU57 is a complement to the BD529. Both are 100 volt 2 amp devices, with a power dissipation of 1 watt in free air.
And by modern standard they are "slow" with a 50mhz ft.
The BD238 is a replacement for the MPSU57.
There will be lots of possible OK substitutions, even TIP41C and TIP42C although check the pinouts.
Is it worth it ? 🙂
Is it worth it ? 🙂
Thanks Mooly 🙂
For the ft parameter in a transistor if i understand, more important is the value Ft better is the transistor ?
"sorry for my english i hope you understand 😱"
Thanks a lot 🙂
Thanks a lot 🙂
I would leave those transistors on the pcb if they work, it it not worth it at all to change them better change the electrolythic capacitors on the pcb these will have dried out after all these years and maybe the old carbon composition resistors they might have some moisture damage.
better change them for metal film resistors and those big white wire wound resistors have quite some induction better change them for some power film resistor.
Greets Nice amp by the way🙂
Thanks Captain archer 🙂
have you got link for power film resistor please ?
for the amp i see that in module do you think the amp will have a similar sound ?
GPA100M - Modules audio - Modules - Awatronic, composants lectroniques
or
GPA100MF - Modules audio - Modules - Awatronic, composants lectroniques
thanks for you help 🙂
or
Thanks Mooly 🙂
Thanks a lot 🙂
Your english is fine...
The ft parameter of a transistor is the frequency at which the current gain falls to 1.
Many old circuits (amplifiers) omit frequency compensation networks etc as the transistors themselves are a natural if slightly unpredictable limiting factor.
Although unlikely, it is possible to run into stability issues, oscillation etc through using devices that are much higher specified than the originals.
That amp appears to have a differential transistor at it's front end so if it has a 'sound' (it alters the sound - to make it sound different than other solid state amps), it may not be operating properly.
For the price if those modules, try them and find out how they sound.
But they are a bit different so you will get a slightly different sound.
but remember if you decide to use your old module replace the capacitors, this is priority ONE.
Believe me it makes a great difference to old amps replacing those caps
look at this page: Rsistances de puissance 5W - Rsistances de puissance 5W - Rsistances - Awatronic, composants lectroniques
and then resistance KN5PWS0R33 this one has a puissance of 5 watt and should be a film type.
And Mooly is right if you use to fast transistors, you could get instability problems like oscillation, so better leave the originals in place.
Greets
Greets
i think i'll try this mod amp 🙂
but i have a problem with my smps 😕
i have four IRFZ44N on the power supply and after +/- 30 seconds i can here a noise 😕 this apear after i touch a resistor who are verry hot 😡
i don't know why this apear, so i power off the smps immediately because i'm worry to have a caps or something that explode in my face 😱
i use a supply of 12 volts with 5 amp to power up the smps and the smps have 2 fuse of 15 Amps
but i have a good output voltage 😕
the noise is a whistle who becomes increasingly high 😕 i'm not sure
a photo of the supply with resistors(surrounded in red) i have touched because they are verry hot (it's 22 ohms resistor"
have you got an idea of the problem please ?
Thanks 🙂
Thanks 🙂
For class D, IRF has an app note for exactly this.
http://www.irf.com/technical-info/appnotes/an-1070.pdf
Thanks midnightg35x 🙂
but it is only a power supply not a classD amp 😕
but this document is verry interresting 🙂
but before the irfz46N i have 4 buz103AL
Is possible that this problem comes from the irfz46N ?
You really wouldn't notice the damping factor dropped to 4? I don't think it would be dramatic but I believe you'd notice under some conditions.
G²
- General Interest
- Car Audio
- how choose a transistor to have a better sound
