How changing LTspice DC-output listing
After you run a .op sim, then select the node on the schematic it shows values in non-scientific notation, using mV etc
I do wish I knew a way to round off these voltages, as 10uV resolution is not needed in many circumstances.
Thanks rsavas.
Yes, that is the way to get rid of those scientific notations.
I do remember that when I was working as a senior analogue I.C. designer ( I am now retired)
that in Cadence, the analyzer program we used in those days, I could put in my circuit listing a line (forgot what that was) to circumvent the scientific notation in the output listing.
But your suggestion is something which I can use.
Thanks again.
