Dear all,
I got a pair of UTC A22 (500:500/125). I want use it as the output transformer in pre-amp. However, I don't know how. Any workable workaround method to use it in 6SN7 pre-amp....?
Or any suggestion to use this transformer?
Thank you.
Happy Diy
Car
Thank you.
Happy Diy
Car
Well,
Why not.First try to found 7233 tube.
Make a CCS load for it at let say 25mA.
Use parafeed linestage configuration with
A-22 1:1 set-up.
That be simple stage OK with CDP.
Joe
A-22 1:1 set-up.
Joe
Hi Jozef,
Thanks for your reply. I'm newbie in DIY Tube Amp, I don't have much experience on CCS and parafeed linestage. Do you know any example available in the web? 🙂
BTW, may I use 6SN7 instead of 7233?
Once again, thanks Jozef..
Happy Diy
Car
Happy Diy
Car
Hi Car,
You A-22 it's only 500 ohm so you can't use it with 6SN7.
Plate resistence of 6SN7 will be around 8 kOhm that mean you needed
at lease 15 kOhm trafo to work with this tube.
7233 is a regulator triode with plate resistence around 230 Ohm.
This only tube I know that maybe work with 500 Ohm trafo.
About CCS and parafeed I proposal you start with DIY Forum
search engine.
Good Luck !!!
search engine.
Good Luck !!!
Hi Joe,
Thank you very much for your reply....
For ccs and parafeed, i will try to search in this forum.....
Thanks....
Happy Diy
Car
Thanks....
Happy Diy
Car
Hmmm...
Using a tube with a µ of 4 and a Zo low enough to kick but the lowest impedances I wonder why one would want an OPT to couple it to the next stage?
I could think of some uses but in most cases they just seem like a forced implementation to me.
Anyway, do as you see fit...
Cheers,😉
Hmmm...
Cheers,😉
- Tubes / Valves
- How can I use UTC A22 at OPT in pre-amp?
