hi..i have emu1212m balanced sound card..and i want to connect it to my denon pma495r integrated amp..can i do it with only a cable xlr and rca.how can i do it..i am tired
Rane web page shows all the options.
In there is the balanced (XLR) to unbalanced (RCA phono) cable and how it should be connected.
a very special problem
hi Andrew.i am hearing sound with denon amp now.but i have a very special problem..when i was working with my f5 amp ,220volts touched to my soundcards left channels cold cable.it burned.after that i replaced opamps with lm4562..now there is a little signal with noise on the cold side of left channel..the left channels hot side and the right channel are ok..sound card works but i cannot use it as a balanced card..i cannot use both hot and cold sides of the card 🙁
how can i use it healty for using with f5 amp?how can make a preamp for f5?because emu card has line level output and i have to build a preamp for f5.
i hope i could tell my problem..i wish you can solve it
I cannot help.i was working with my f5 amp ,220volts touched to my soundcards left channels cold cable.it burned.
now i am playing it as an unbalanced card..i am using only the hot and sleeve of card.it sounds nice..i solved the problem.thank you
