I want to test my gainclone, but there's a small problem:
the gainclone has RCA inputs, and the frequency generator has a BNC output, and uses coaxial cable.
For sure, I'll have to build (or buy) a BNC->RCA adapter. But what should I put in it?
Only 2 plugs, nothing more? Or terminate the coax line with a 50R resistor from live to ground?
Alex
Alex
Many surplus shops sell such converters:
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=BNC-RCA&type=store
I would not worry about termination; test your amp with the termination you expect to use in the real world. (i.e. 10k/20k etc, not 50 ohms!)
Hi Bricolo,
From many hi-fi shops there are also 75 coax cables available with a RCA cinch at one side and a BNC at the other side. These are intended to connect (home) video equipment together. Such a cable serves me pretty well for the same purpose as you have.
Cheers 😉
Cheers 😉
