homebrew 18 watt problem
I have an old hammond amp that I am converting for guitar, the amp worked before but now I only get sound for maybe a second after it warms up then the sound fades out to nothing. If I turn it off for a second then turn it back on I get another second or so of sound then nothing, any ideas?
I'm assuming that when you say it "worked before", that you were getting guitar sounds and the amp worked properly. If that is the case, check your preamp tubes one by one. Try swapping them until the problem goes away. It sounds like one could have a bad heater.
