I recently purchased a tube pre amp and would like to install a HT bypass. I got the Elma selector switch and would like to use the existing pre amp output.
How would I go about wiring in the bypass without interfering with the pre amp circuit. I tried just straight wiring but there seems to be interference with the circuit - feedback.
Any ideas, guidance from knowledgeable diy'ers
Thanks and cheers
Thanks and cheers
Joined 2009
You need to make sure that if you are just connecting the input to the output with a bypass switch that you have the pre-amp powered OFF or you are creating a positive feedback loop.
