Hello,
I am hoping that you would be kind enough to help me with a question. I would like to use 4 LED's for a solar powered lamp that I am building. Would you be able to tell me exactly what kind of rechargeable batteries I would need for the 4 LEDs and if I need resistors? Is it necessary to have a pcb board for this project? And finally, maybe it's a longshot but does anyone know if there was a kit available for an outdoor solar lamp? Using the solar path lights just wouldn't provide enough light in the lamp.
Thanks in advance.
Thanks in advance.
Hello,
Thanks in advance.
Well, I don't know which LEDs you will use, but obviously your battery voltage must be higher than the LED voltage. Or you can use a lower battery voltage and put the LEDs in series/parallel. Be aware though that LEDs need to be driven by a constant current because it is very difficult to drive them from a constant voltage due to their badly defined and steep V/I curve.
So at any rate you want some kind of adjustable current source; there are lots of ICs for just that purpose so a search on the net might be usefull.
Did you search the Elektor forum, they may have something like that already.
Jan Didden
