I am a newbie considering building a home brew Ampeg B25B bass amp. I would like to follow the circuit diagram below where possible:
http://www.unofficialampeg.com/schematics/b-25.gif
I know a LITTLE about electronics and I am trying to read as much as possible before building, which I won't even contemplate doing until I am certain every thing is theoretically correct and completely safe - I have my dad (an electrician) to advise on the safety side though no amp tech to ask any detailed questions of which is what brings me here.
I intend to use a Lundahl LL9202 for the output transformer and an Antek AS-4T500 for the mains transformer. The specs are below:
http://www.lundahl.se/pdfs/datash/1620_3_7_9202.pdf
Antek - AS-4T500
My problem is the Antek AS-4T500 only has 2 6.3v secondaries so I can't use the GZ34 and will have use a diode bridge - as the amp is intended to be used as a bass amp this doesn't bother me that much. I would like to follow the RCA specs for class AB1 and try to get around 70-75 volts by putting 540v on the plate and 400v on the screen as per below:
http://www.drtube.com/datasheets/7027a-rca1959.pdf
If any one could help me to modify the B25B circuit diagram to replace the GZ34 valve rectifier with a SS diode bridge and up the output to circa 75 watts aper the RCA spec I would greatly appreciate it!!!
All comments welcomed.
Jamie
Antek - AS-4T500
Jamie
You can replace the tube rectifier with 2 discrete diodes(ignore heater V), I have done this on an old Gibson amp the only complication is that your B+ voltage is higher than spec however this should not be a problem . recheck the o/p bias afterward . That being said GZ34/5ar4/5u4 should not be that hard to find, tube rectifier acts as a soft start as the rectifier tube has to warm up to allow power to everything else. 500v is a little high for a 7027 , 400v is more like it I like the sound of 425-450 EL34 is a little more sturdy tube for higher plate V. 6L6/6V6(my fave)/6CA7 and they like 470 ohm grid resistor . KT66/6066/EL34 likes 1K grid resistor. hint being Fender like sound or marshall like sound. Groove Tube has a book with insight and Schematics for every popular amp ever built with a bias current spec for all o/p tubes at every voltage(second hint high bias low tube life great sound catastrophic failure when tubes die)
Regards, Elwood
Regards, Elwood
