High voltage psu
Hello
I use some of my time at tube amplifiers and that is the reason I need a regulated power supply (transistors 😎 ).
Variable output voltage 100 - 350 (400) voltage
Current 100 mA. Short circuit protected
Schematic wanted.
Benny
Look for a Heathkit IP-32
I do not have the schematics for these unit but the specs are very close to what you need.
Three simultaneous Outputs:
Main (B+): 0 to 400 volts DC, 100 mA continuous, 125 mA max intermittent
Bias (C-): 0 to -100 volts DC, 1 mA max
Filament (A): 6.3 volts AC, 4 amps max
B+ Regulation: output variation less than 1% from no load to full load, for outputs of 100 to 400 volts; output variation less than +/-1% for a +/-10 volt variation in the 117 volt AC input
B+ Ripple: less than 10 mV RMS ripple, jitter and noise
Find a schematic and you can build it yourself.
-- josé k.
the TL783 is designed with a smaller range of input voltages than the LR8N3 -- you could effect the same result with an LM317 --just protect such that the input to output voltage is limited by the zener.
the supertex devices was designed as a supervisory circuit regulator for off-line SMPS -- just repurposed.
