I have searched the forums and haven't found anything. I want a 1500va 49 volt secondary transformer with 120 primary. This is for a Wolverine build. What's the best out there?
https://www.antekinc.com/an-15450-1500va-50v-transformer/
50v, but close enough. Can cap off the 12v secondaries or use them for something neat like relays or meters.
Is a Wolverine an Arc Welder? 😉I want a 1500va 49 volt secondary transformer with 120 primary. This is for a Wolverine build.
jeff
No you don't.I have searched the forums and haven't found anything. I want a 1500va 49 volt secondary transformer with 120 primary. This is for a Wolverine build. What's the best out there?
You need a 49Vac + 49Vac transformer, not a "49 volt secondary transformer"
Yes, it sort of is. With that supply voltage I would think that 500VA is "normal audiophile overkill" rating and 800VA is way more than necessary for a class AB amp. I doubt going to 1500VA is going to do much except waste money and space. Also, 50VAC is going to be very close to the max. voltage as far as I can see from the schematic, so maybe consider going to 45VAC instead?Is 1500va @ 50v to much?
You are having difficulty because 1500VA is a silly big transformer.
Toroid Corporation of Maryland makes great transformers up to 1000VA. https://toroid.com/power-supply-transformers-toroidal
Ed
Ed
If you meant 50VX2, it's just nice for 2 channels!Is 1500va @ 50v to much?
I am glad for the education. I thought going oversize would give the amplifier slightly more headroom because the power supply won't sag. Is this not true? I am learning this on diy projects so all the advice is definitely appreciated.
Thank you I will start to use the correct terms. So that should give me around 70 volts dc ?No you don't.
Original project in its power supply section suggests picking a lower voltage PT (45+45Vac?) If overspec 'd "because it will sag less"I am glad for the education. I thought going oversize would give the amplifier slightly more headroom because the power supply won't sag. Is this not true? I am learning this on diy projects so all the advice is definitely appreciated.
Straight from the horse's mouth 😄
The 2x 42V, 1000VA model should work. The 2x 38V, 820 VA model should also work. These are large transformers.
Ed
Ed
I was going by the build guide. I saw a 1200va 50 volt ac transformer. That would be 71 volts dc at the rails? Recommended for oversized. 430watts @ 4 ohms. This is where I obtained my information. I also see manufacturers of amplifiers like Parasound have large va and capacitance for their power supply. Is this just a sales gimmick?
No. They use the transformers that give the sound they want. In the case of Pass Labs HPA-1 it was reported by them that they went through six prototype power transformers before they got to a version they liked. According to people who know, it does have an effect on the sound of that particular circuit.Is this just a sales gimmick?
Other amplifier circuits may be different though, so its not always better to randomly throw in oversized transformers just because someone else did. Also, even if a little bit oversized can be good in some cases, going too far with oversizing can sound worse.
@Markw4"going too far with oversizing can sound worse."
Hi, How would that happen if you care to explain.? I never heard that an oversized transformer can sound worse. Just curious !. - Bruno.
- Power Supplies
- High quality transformer
