I have been using LME49713 in the past but digikey now has this as non-stock. Any alternative with the same pinout and similar performance?
Warning ! LME49713 is a special opamp : current feedback. Even if you find a similar device, it will be necessary to modify some components to obtain similar results. Be prudent !
Thats fine I'm just looking for something similar.
check out this threads to the the same resp. similar topic:
http://www.diyaudio.com/forums/solid-state/132471-national-opamp-inflation.html
http://www.diyaudio.com/forums/chip-amps/154106-best-sounding-audio-integrated-opamps.html
http://www.diyaudio.com/forums/solid-state/54199-best-opamp-opine-please.html
http://www.diyaudio.com/forums/solid-state/160149-lme49990-audio-op-amp-better-than-ad797.html
http://www.diyaudio.com/forums/parts/41234-best-audio-opamps.html
