Hifonics TX1200D
Hey Guys,
I decided to stop working on the expensive STEG K2.02 and start working on a cheaper one, because these are my first Car Amp repairs.
Ok so now to my patient.
First i recognized prior repair attempts. As you can see on the picture.
What will help me a lot, would be a service manual or a schematic of this board.
I thermal imaged the PCB when power on the amp.
IC50 (HIP4080AIPZ) is getting hot and ZD10 and the 2 330 Ohms Resistors.
Also theres a prior attempt with the white jumper wire.
Where to start?
Thanks for the Diagram.
I miss the Zener in this Diagram.
Did you know what value of ZD1C?
I also pulled the 4080, but nothing changes.
Diode goes up to 90°, then i stopped applying power to the amp.
What i also discovered with my Handheld Oscilloscope:
HIP4080A
Pin 6 Triangle wave as it should be
Pin 7 100mv 50Hz Signal no matter what frequency i play through RCA (is that simply noise?)
