Please help even after disabling Driver Signature Enforcement all i can get is a
" USB device not recognized " message !
You're talking about this thing ? With the Tenor Te7022L receiver ? It's a very basic device so if it has stopped working, try to connect it to a different computer. If it still doesn't work contact the seller. It could well be faulty.
Thank you KlipschKid for your help . It might be the case . It worked for 3 minutes and after that nothing .
tt
tt
Try a driver - you can download one here :
Teralink X2 - 2012 Version Native 24bit/96k USB Converter
Try reading this about code 43, and if that doesn't help, return it.
How To Fix Error Code 43 (Windows has stopped this device because it has reported problems)
I found out to be my motherboard compatibilty problem , because the device works in other computer running Windows 7 32 bit . The same Windows 7 32bit installed in my board still gives error code 43 . Thank you again KlipschKid for giving me attention . Regards .
Pleased you found the source of the error. Hifimediy should pay me eh ?
Good luck with the mobo....
- Digital Line Level
- Hifimediy Sabre dac on Windows 7 or 8 64bit install
