Hi specs rectifier needed
Hello, i'm going to build a KT88 PP amplifier, and i'd love to use a direct heating rectifier tube... the problem is that i'm having trouble finding a tube capable of these specs: in AC 550v 200mA, because i need 600v after filtering... any ideas??
Hi!
Sorry did not see dht requirement before posting
The 5R4 you mentioned IS directly heated...
But why insist on DH rectifiers? If you open yourself for indirectly heated rectifiers an abundance of choices opens up: TV Dampers. They can easily handle the voltage and current requirement. However If you have not settled on the power transformer yet, go for choke input supply and a full wave Graetz bridge.
Best regards
Thomas
In the olde days, it was common to use two dual diodes of lower voltage rating in a doubler configuration. The dual diodes in each valve were paralleled to cope with the higher current levels, and the advantage was that the diode voltage spec didn't have to be high, and the filter caps were placed in series and clamped to half HT. The disadvantage was you needed 2x 5V heaters.
However it is sometimes difficult to design the capacitor for valve rectifier circuits, especially doubler, as the ripple current ratings are quite low for low uF electrolytics with high voltage ratings. The only simple workaround is to use larger uF caps of lower voltage rating in series. Many possibly don't check the capacitor ratings.
Ciao, Tim
