Hi, It's about Quad's & Revoxes
Hi Stefaan,
Welcome to DIYaudio! Great Quad site!
With the A-77, replace all those white tantalums with electrolytics, even on the capstan motor servo board. The trimmer controls fall apart easily. Don't know if you knew that yet or not.
-Chris
I bought an A77 in 1970 which had 3 problems. The relays on the motor control board did not have contacts with high enough current rating so the contacts would erode and stick. Replaced the relays with relays having 5 ampere contacts.
The 5 watt resistors on the same board were too small and they would overheat and char. Replaced them with 10 watt resistors.
The friction material on the brake drums was a synthetic which would get stickey if it got hot (heavy brakeing) and then stick to the brake band when it cooled and prevent the reel motor from turning. Replaced the friction material with an all cotton fabric.
Regards,
Ray
Ray,
You missed all those darn caps!
Brake bands are normal maintenance items. Your's sounded like they were very old. The relays can go bad, not that much of a problem. The bearings tend to go. Very easy replacement. On and on. Oh yeah. The counter belts always seem to break, and the older counters that use a toothed belt, newer ones used gears.
-Chris
