• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Hi-end Power cables
This is DIY high quality hi-end Audio power cable. It is completely hand crafted by audiophile to audiophiles in the USA with quality materials. Used conductor is high quality power control copper cable. Construction is 3 x 12 AWG per phase and null. Shield is grounded for better protection of EMI/RFI and low frequencies. It came out of search for reasonable priced and jet hi-end class cable. After modifying and checking several cable brands the search begin with this as a final result. After testing on various systems, I came to conclusion that this cable is comparable to any hi-end hi priced power cable by any mean.
Sound: This cable will improve the dynamics, transparency and details with soundstage on almost any equipment. Sound is more natural and controlled. Bas is precise and deep, highs are more detail and fast and soundstage is wider. It is especially suitable for amplifiers, power amps and or preamps.
It will work on CD-DVD players with also noticeable improvements. On video equipment it will improve the quality of picture - contrast/dynamics.This is must have for all hi-fi and hi-end audio/video systems.
Details:
Cable Diameter: 0,6in or 14,6mm
Length: 3ft or custom.
Conductors: 6 x 12 AWG (2.50mm2) Finely stranded copper fine wire
Shielding: Gray PVC inner jacket; tinned copper braid (85% coverage)
Jacket: Transparent PVC, Insulation: PVC
Finish: Black stretch cable sleeve velcro sealed
Connectors: US AC Power Plug & IEC 320 Connector Gold Plated Transparent Red, 079 (Oyaide copy)
Application Advantage
multi-conductor power and control cable with a galvanized braid shield
Braid provides protection from low-frequency noise
Pressure-extruded jacket for improved flexibility
Technical:
Minimum Bend Radius - shielded: 6 x cable diameter
Nominal Voltage up to : 300/500V
Test Voltage:4000V
PRICE : 100$ Shipping included. Will ship in the USA only.
If you don't like it after 1 week test period I am willing to take it back with full refund. You will have to pay the shipping back only. If you do like them, and I know you will please share and write your opinion and conclusions.
Thank you
