hellow everybody
does anyone know where can i find schematics for some of the commercial expensive amps , i want to know what they put in there that makes those amps so damn expensive , are they using special made transistors , parts ...... ?
I think there is nothing special except that they use expensive capacitors, which DIYers also have access to. I found some complex circuit, but the main circuit is standard, mostly use paralleled MOSFETs (also in Accuphase). Only in Audio Research I have seen bipolar. So I think (may be) the damm high price is coming from the patent? But accurate component values and matching can be part of an expensive system too.
In general, the price is a function of demand, not "quality".
i also found a chematic that looks normal but with many
paralleled output transistors , so , theres nothing special i guess
sss said:hellow everybody
For the most part, there's nothing really special in most equipment. I don't know what's in some of those $40k sealed monoblocks that I've seen reviews of, but for most 'reasonably' expensive hi-fi stuff, there's nothing too special.
A lot of the cost comes from design and manufacturing. Somebody has to design a circuit that sounds good, measures well, and uses few enough components, or, at least, the right components, that it can hit the price/performance ratio necessary for the company to be able to sell the product.
Additionally, there may be some cost involved in ensuring that the circuit doesn't make unlawful use of anyone else's IP. So you have a couple engineers and a couple lawyers getting paid before a single product even ships.
The equipment needs to be tested, as well. So add the cost of a suitable testing ground, a wide variety of associated components (speakers, interconnects, preamps, sources, etc), measurement equipment, etc. And labor costs will probably be high for anything made in Europe or North America.
If a warranty is offered on the equipment, the cost of it (cost to replace/repair unit multipled by rate of failure over warranty period) will be added to the price tag.
And add to all this the cost of parts, out-sourced manufacturing of PCBs and chassis, marketing, customer service/tech support, whatever fees are involved to get the device certified for use in the countries it's sold in, insurance, facilities, etc. And finally, enough profit to make the whole effort worthwhile.
And this is basically why DIY can be so great--you find yourself a design that has a good reputation, you shop intelligently for the components, you build the thing in your spare time, and eventually, you have a high-quality, relatively low-cost amplifier.
Why the high prices?
I think we should also take into consideration that some of the best amps are really also works of art. The whole assembly is a pleasure to look at. That takes lots of time - expensive time. In addition to all this it would have taken a lot of time to audition the design and evaluate its performance so that the end user gets a really good sounding amp. That again takes a lot of expensive time. Eventually all the months of design and development will have to be charged for as if it were a cash investment. That will be inflated by the ex factory costs - distribution , advertising , dealer margins etc. So as the units are usually made in small numbers they end up being expensive.
Now I am talking about the people who are really dedicated to bringing you good sound.
Unfortunately the market is such that it is not very difficult for not so 'fanatic designers' to make pretty products for enormous prices. Their margings are higher as they do not go through the time and trouble that the dedicated chaps go through.
You will have to study each product well before you buy it. Those who spend less money on the outside and more of it inside the product , generally make better sounding products.
The moral is that it is very hard to determine the "value" of a product by looking only at its component parts. The major costs are invisible but "audible" !
Cheers.
Cheers.
Re: Why the high prices?
I have just read the Gainclone vs Discrete debate initiated by DrG. As a knowledgable person in electronics, he really had a point. But I know from experience that average or most DIYers are not even close to his capacity.
I often proud of myself of being able to create a good sounding system. I know that the same amp circuit with the same source and the same speaker can be tweaked differently to achieve a good sounding system. It is very easy to tweak chip based amp to achieve a good sound. Basically it is an effort to fight oscillation to employ small (unity) gain and to design suitable speaker. But tweaking (not even designing) a discrete is a real headache...
I usually am not afraid comparing my optimized system with many higher end systems. This is not a bull-sheet knowing that I usually have expensive gears I left unused (or untweaked). If only you could agree that a single "wrong" cap at the wrong place can ruin all the system performance, and right components at right places can deliver a good sounding system... Too often I heard bad sounding expensive systems simply because the owner wrongly match the component brands. What will you say if a top class amplifier and source is fed to an expensive speaker, but you can hear a "grunge" as if the amp crying for more current? Or you hear a resonance of the speaker cabinet?
So you know the price of my system. It's not the components used in the system, it's my time dedicated to the system. (A waste of time that brought me a bad career, and a 9 years in universities...
ashok said:In addition to all this it would have taken a lot of time to audition the design and evaluate its performance so that the end user gets a really good sounding amp. That again takes a lot of expensive time. Eventually all the months of design and development will have to be charged for as if it were a cash investment.
I just remember now how much effort I had given to tweak my Bride Of Zen from noises.
I blamed myself from not having oscilloscope and pittied my ears from not able to work
independently against power supply noises and distortions...
Only yesterday (after I discontinued the BOZ for a long time) I found that the ALPS pot
used in the pre-amp introduced terrible noises! 😡
Good topic!
The answer is simple: The market can take the price regardless of the content.
Some products have high production costs and some have not.
All products have small production series though.
Some products are worth the money and some are just rip-offs (Gaincard, production cost small, development cheap).
A high end that many pros consider worth the money
http://www.bryston.ca/schemprod.html
The warranty is clearly one of the best I've ever seen, for any product in any industry. Speaks volumes about the manufacturer's confidence in their product.
🙂ensen.
🙂ensen.
Great and reliable design indeed. If only it could also play music...
Speaking of warranty, one of the costs that go into a commercial product is design for reliability so that returns under warranty are minimised. Few things will sink a small to medium (or even some big) companies faster than too many warranty returns. And "too many" isn't very many. It's hard to grasp unless you've been on the inside and seen what it costs, but even a simple repair cost a significant fraction of manufacturing a new unit. Beyond a certain point, which comes on pretty quick, it is cheaper to supply a replacement unit.
I'd guess you don't like them.
🙂ensen.
Marketing and sales are a major cost for high end stuff. You really do need to have ads in magazines and those are pricey, AND you don't have a huge production run to amortize the cost. The upscale audio Salon has a high rent.
If they have non pushy salespeople, that take their time actually helping you, you are paying for that time (and should)
I don't think they manufacturers are ripping people off, they are just playing in a very small pond
Variac said:Marketing and sales are a major cost for high end stuff. You really do need to have ads in magazines and those are pricey,
Not to mention the cost of bribing reviewers.
Re: Re: Why the high prices?
u see the problem is that most hi end amps dont need to be tweaked because they should work with any type of speakers not just the speakers of the same manufacturer ' so imo they dont spend allot of time tweaking it .
"u see the problem is that most hi end amps dont need to be tweaked because they should work with any type of speakers not just the speakers of the same manufacturer ' so imo they dont spend allot of time tweaking it ."
... which indicates one of the advantages of DIY - you can build your amp to go with a particular speaker. Rod Elliot has an artical about modifiing output impedance to optimize the amp/speaker interface. Of course many speakers are so plain vanilla that all you need is a plain vanilla amp. Still . . .
i constantly visit Rod Elliots site (great website!) but i rather make as low as possible output impedance amp
Re: Re: Re: Why the high prices?
The price is a function of market demand.
The market itself demands high quality products (as of their own criteria).
The (expensive) gears market is filled with (wealthy) people who don't know Kirchoff Law.
It is then important to ship a product that sound good at any condition.
Such products require a good R&D, inventions, etc (simply said: tweaking)
Once you have found a great product, you can sell them at high price,
to compensate for the R&D (and intellectuality) cost (not production cost).
I can't see any reason why you can be off to court just because you sell
a product comprises of gaincards for $50,000, as long as it sounds good.
You are right that popular product tend to work with ANY speaker, and it
sometimes requires R&D (simply said: patent). ISC (Impedance Sensing Circuit)
and Aleph Current Source are IMO fall into this cathegory. I believe you don't
need an ISC in your amp...
IMO, the more expensive the product, the more you need to pay attention to deatils.
For mass cheap products, you can hire cheap engineers to do the plug-and-play production.
Isn't that nice to create amplifiers where the resistors are all 10K and the capacitors
are all 10uF? 😉
sss said:u see the problem is that most hi end amps dont need to be tweaked because they should work with any type of speakers not just the speakers of the same manufacturer ' so imo they dont spend allot of time tweaking it .
are all 10uF? 😉
Re: Re: Re: Re: Why the high prices?
I've checked some schematics and i saw no special sensing circuits , most of the high end amps got multiple output devices , one of the advantages is that the output impedance is low
(i'm talking about BJT based amps not tubes and other stuff)
that should work with all "normal" speaker types - no tweakng needed.
tube amps got higher output impedance then bjt amps thats one of the things that make them sound different (or better for some people) but when we are making transistor amps , isnt our goal is to get as low as possible output impedance?
- hi end costy amps
