HF receiver front end IC
A chip can do amplification, but for selectivity you need filters: LC, ceramic or crystal are the usual technologies used at HF. Alternatively, there is the software-defined-radio approach, in which most of the filtering is done digitally.
For receiving a single fixed frequency the simplest techniques might be either TRF with reaction, or direct conversion (also known as zero IF). Google will help you.
