I'm restoring a pair of Bogen MO-100 (the ones with a pair of 6550) and I need to replace the power cord.
The strain relief is made by Heyco and I found a lot of info on how to remove it, but they all mention the Heyco strain relief which is ~$50 new (saw ~30 on eBay. Does anyone have a cheaper solution?
Elias
Elias
I have a pair of the Heyco pliers and if you do a lot of repairing they are worth every penny. Regular pliers will work in a pinch but the strain reliefs usually get mangled and the chassis gets scratched.
Craig
Craig
Craig
Thanks. I actually just found a $20 strain relief pliers at amazon.com and there were a few comments that it worked fine on the Heyco. I ordered and will try. If it doesn't work I'll return and get a Heyco.
Elias
If the jaws are thin and can fit between the chassis and the large part of the strain relief you should be OK.
Craig
Craig
History of the Heyco company (family owned since 1926):
https://www.youtube.com/watch?v=4OYlxd3sXOE
Use of strain relief plyers:
https://www.youtube.com/watch?v=G1IWQB3mQrw
Yes, I saw those. Pretty cool.
Thanks again.
Elias
- Design & Build
- Parts
- Heyco strain relief pliers
