I was going to make a cable for my nview by cutting a vga cable end and putting on the db15 male, but relized i do not know what color wires corrispond to what number pin? Can someone please help?
You need a cheap volt meter
You need to use a cheap volt meter, and set meter in resistance mode, this way when you find pin1, you can see which wire that pin is wired to.
