Everytime the bias reach 10mv, the bias raise itself, it jump to 20 or 30mv right away.
View attachment Simetries Folded Cascode New Com amp.pdf
Select a better more appropriate value pre set to match the knee of Q9 and Q10.
I note there is no temperature sensing arrangement. Are the bias array transistors thermally connected to the power transistors?
I changed r18 and r19 to 560ohm and r16 1k7 if I didn't, the bias will raise immediately.Select a better more appropriate value pre set to match the knee of Q9 and Q10.
Yes, the Q9 and Q10 on the same HS with the final transistor.
