Help with sharp qa 2500
Okay I have read alot over this issue, about the power supply.
On the projector panel there is four pins for the power
The Left top is +5volt
The bottom left is +12volts
The grounds are both on the right bottom and top
This is how the pins look right
This is all from looking at the projector panel input not the actual cable, but the manuel is correct people just need to read them more closely, This is what i found so far.
I need to figure out how to make a power supply because i dont want to f****** a $177.99 projection panel off ebay, i would have just wasted 2 weeks pay.
I need to see how to make one from a Computer power supply
Any help will be appericated thank you
